2007 GT3 Brake Rotor Cracks
Just ordered my set from DeMan, I will let you guys know as soon I get some experience with them.
GT3 player par excellence
if you measure motorsport vs oem steel disc's with a micronmeter, yes, motorsport is thinner. but last i check the rough price difference was $250 per axle with motorsport cheaper. they last equally as long
Moderator
I probably never get more than 25% of the wear out of a set of rotors as they crack up from track use before then. Therefore, I would say that anyone that tracks a car can use either OEM or Motorsport rotors and get exactly the same use out of each set.
The braking feels about the same initial and while at the threshold and allow me to use my well known braking points so they are just as effective and perhaps have a little more left if the tire would give it to me.
I will post back again after 5-6 more track days about the thickness and life expected.
