Camber shimms Part Nos.
I am trying to order some 5mm and 7 mm front camber shims for my 997-3 and I searched for part numbers and found Rogers post
99634154390 - 4pcs (Camber adjustment shims)
99634154393 - 4pcs (Camber adjustment shims)
I gave the numbers to my dealer and he did not have a description of what they were other than shims. He thought this was for One shim each part number so he did not think it was for more that one and could not tell me which ones there were. So any idea how to order what I want. My dealer does not think its a 4 pcs set.
Update Sunset Porsche fixed me up the 390 is a 1mm shim the 393 is a 7mm shim and 392 is a 3mm shim they tell me they do not show a 5mm shim so i ordered 3 & 7. the 7mm shim was like 23.00 and the 3 mm was 13.00. fyi.
Here are the part numbers I have:
996.341.543.90 shim 1mm
996.341.543.91 shim 2mm
996.341.543.92 shim 3mm
996.341.543.93 shim 7mm
(but no clue on qty and price is pretty steep for the 7mm.)
Be aware that if you put 10mm (7+3) shims on the front control arms, you will be rubbing tires on the radiators (they are ahead of the fender liners, so you know what happens to these liners)
