Airbag light shutoff
Welcomd to the plug, er I mean Club. thats a dealer only jobbie.
I did that in my 996 with the seats and roll bar.
$86 dollars later.....
As many of you know, when you install aftermarket seats (or even Porsche's GT3 seats) you'll end up with an air bag error when you start the car. You will also get an AWS (Automatic Weight Sensor) fault (you don't seen any errors but the Passenger Seat Airbag Off light in the center console lights up).
Turns out it is a trivial task for your Porsche dealer to set some ECU options to deal with all these faults. All you need to do is ask them to use their diagnostic computer to program the following options:
• Driver Thorax Airbag : No
• Passenger Thorax Airbag : No
• Driver Seatbelt Buckle: No
• Passenger Seatbelt Buckle: No
• AWS : No
No more error codes
GT3 player par excellence
I wouldn't use a jumper.
Do some research and get it right
I have installed the 7 CF seats and proceeded to the local dealer in my area to have fault codes removed. They all looked at me like I was crazy. The dealer refused and called PCNA to verify that they can't assume liabillity. How did you guys get the dealers to do this?
