How much rear wheel camber for street use..
I'm taking it in for the one year anniversary oil change. I have 2300 miles. Inside edges of MSPC showing some wear. My question is, for street use and tire life should I have them take some camber off the back wheels. It is set at whatever it came from the factory with.
If you reduce rear toe and Rear Negative camber , You WILL get more tire life. You will also notice more tendency towards oversteer so be aware and use caution. I often change my street only cars away from factory alignment to get significantly better tire wear.
