Corner balancing question...
After corner balancing is the passenger side of the car higher than the driver's side? In my car the rear wheel fender on the passenger side is at least 1" higher than the one on the driver's side...
I believe it should be slightly lower, and the front driver side fender should be higher. The idea is that when you are in the car, with the added driver weight all corner should be roughly at the same height.
