Track alignment for GT3
Platinum Dealership
Larry I'm running stock MSPC 19"s. I've also got solid bushings on the back to shorten wheelbase with caster, therefore making the car much easier to rotate with my right foot mid corner. Turn in has really been helped with the lowering, sway bar settings, and toe settings.
as of right now, my tires wear evenly from outside to inside and my COLD pressures are 27-29 depending on air temp. HOT pressures that the car feels best at- 34 all around.
I might try some toyos in 19 but probably will just keep it stock street tires in terms of rubber. when I deserve more grip, I'll get a cup car for myself.
