997 GT2/GT3 Forum 2005-2012
What's That High Speed Shimmy I Feel . . . ???
Old 03-27-2008, 08:18 AM
George3
George3's Avatar
I have to assume the tires were balanced correctly. I bought the tire/wheel package from John at CCW. But you know what they say about assume.
My next event is April 5-6 at Pocono. I'll mark the wheels/tires to see if the tires are spinning on the wheels. And, I'll try to run the car a little harder to take some wear off of the treads. Then I'll see if I notice a difference on the high speed bowl part of the course.
Old 03-27-2008, 08:22 AM
George3
George3's Avatar
Originally Posted by stisseront
George,
It is likely from your tires. I felt the same thing with the r888 full tread. Not a good feeling under braking at 150. This should go away as the tires wear down. To confirm this try a MPSC or a Hoosier and you will not have any of this. I will try to have my next set of R888 shaved to 3/32.
Stephan
I'm not a fan of MPSC and not ready for Hoosiers.
What about the Nitto's ???
Anybody have experience with the Nitto tire ?
Old 03-27-2008, 11:18 AM
str8ner
str8ner's Avatar
Tried the Nittos full tread. Same problem. Shaving may be the solution as well.
Stephan
Old 03-27-2008, 11:29 AM
George3
George3's Avatar
Shaving might be the answer.
I just can't see wasting half the life of a new tire at this time.
Maybe running a new set of tires on a short track for a while is the answer (??) .
Old 03-27-2008, 11:49 AM
doc2s
doc2s's Avatar
george,
one suggestion is to take the oem wheels/tires with you to your next track event. drive on them for a session and see if the problem goes away. if not then you might want to recheck your car's setup (ride height and alignment). sometimes setup changes due to the suspension setting it or things changes during transport ...
when i had tires spinning on the wheels i would feel vibration at high speeds not side-to-side movement.
Old 03-27-2008, 02:09 PM
George3
George3's Avatar
Originally Posted by doc2s
george,
Good idea.
I'll try the OEM's.
Old 03-27-2008, 03:05 PM
str8ner
str8ner's Avatar
Shaving your tires is not a waste. They may actually last longer on the track. They will flex less and build less heat.
Old 03-27-2008, 03:18 PM
George3
George3's Avatar
Stephan,
For 255/35's and 315/30's............
How much would you shave them?
Old 03-27-2008, 03:55 PM
str8ner
str8ner's Avatar
4/32 to 3/32. Do not have anyone do this for you. Have a well not shop do it. Vilven, tireshop, Frisby... Do no use Radial Tire in MD (Paul). Shved a set for me and massacred them. Very uneaven and tire was way off balanced. Then started spinning on the rim. Made it even more off balanced. Blamed it on the wheels letting the tire spin. Were 9ounces off! I never could use these tires and my wife and I trashed a track week-end at the Glen because of this. He never recognize his fault and I had to get red of these tires! $1320 in the garbage! Ran many tires since then and never had this problem again: It was not from the wheel.
Stephan
Old 03-27-2008, 04:04 PM
George3
George3's Avatar
Do you shave all your new tires each time you buy them?
Are you shaving the MPSC, or which tire brand?
How many track days do you get with them shaved? (Assuming one driver... I know you have 2)
Old 03-27-2008, 07:25 PM
iLLM3
iLLM3's Avatar
Originally Posted by George3
My rubbing is on full turn lock on the right wheel only. This is with the 245's on CCW C10's. No issues while driving at speed, because I don't turn the wheel to the full lock position.
Maybe I need a 2mm spacer.
Wow WTF I thought I was the only one with this LOL . People are running 245-275 and no rubbing meanwhile my 245 r888 is rubbing only on the right side at full lock or uneven surface while turning that way so odd...
I also got the same shimmy from my full tread r888's and it got better but was still there into my 3rd day on the track with them.
Old 03-27-2008, 07:47 PM
340Elise
340Elise's Avatar
Yup, that is what I learned as well while doing research on track tires and shaving.
Quick Reply: What's That High Speed Shimmy I Feel . . . ???
