Its official, add me to the RMS leak
#61
Because i work in a dealership that used to see 10x more RMS jobs a week then we do now. Since the redesigned seal I have seen 1 failure and that actually was Bento's seal in this thread, I have done one other 997 series seal and that was in a 05 car that happend to have an old style seal.
Mark
Mark
#62
Mark
Mark
ZBB0730 Thanks for posting the pics of your engine and he plug inserts for me. Is that a sweet looking engine or what. As
As far as the complaints about Porsche and RMS, it is frustrating but its like a good woman we put up with it!
#63
I TOO ALSO HAD A RMS SEAL REPLACED IN DECEMBER AND 100 MILES LATER IN JANUARY LAST WEEK- ANOTHER HAD TO BE PUT IN. PC HAD A FACTORY REP IN FLORIDA LAST WEEK LOOKING AT ANOTHER RMS JOB AND ADVISED MY DEALER TO HOLD UP FIXING IT THEN CHANGED THEIR MIND. MY CAR WAS BUILT IN MARCH- SO WHEN WAS THIS MAGICAL SEAL REDESIGNED FOR THE 15TH TIME- ORIGINAL SEAL FAILED AND TWO OTHERS- NEXT STOP FLORIDA LEMON LAW AND A CAR BUYBACK PER DEALER.
#65
Mark
Mark
#67
Honestly this is both ridiculous and embarrassing for Porsche. They really need to get this worked out because it is a totally unacceptable situation for these cars to continue to have this problem going on 10 years now going back to the beginning of the 996.
#68
My RMS leak is back! I can't believe it!! There is also some other kind of leakage going on -- about a foot and half in front of the leak spot (looking from the rear of the car), on both sides of the car, there is some pink liquid on my garage floor as well. Coolant perhaps? Aarrgghh. Will call the dealer tomorrow -- perhaps the new/revised seal will work? My original leak was replaced in mid-December 2007, prior to the new part.
#69
i had 3 different leaks which you may have
- rms
-8 platform seals
- pulley shaft
#70
hi everyone.
just out of curiosity after reading so many of you still have the oil leaking after all the headache...
what will happen if you just ignore the rms leak but just watch the oil level regularly?
will it leak more and more then pour out eventually, or will the amount of leak always be consistent that you can get away by just being careful with the oil level?
#71
GT3 player par excellence
#73
my RS also has pwr steering leak, not much though.
i was told by my dealer that the car is very sensitive to pwr str fluid loss. the light will go on, until then he told me not to worry.
to add more confusion. my cayman s tracked heavily is always low on coolant. the light never comes up and car never overheats. but i keep topping off, over 6 months i used up one gallon. BUT, it is ALWAYS low when ever i chk it. the light NEVER came up. the car NEVER overheats, and i have never found any coolant leak anywhere i parked...... where did all the fluid went???
#75
'08 RMS leak
Add me to the list of 3s with a RMS leak and it may be the record: '08 with 70 miles. I am having the dealer replace it next week.
Service mgr told me the seal is designed with tiny perforations to relieve crankcase pressure at high revs and when cars sit for long periods (which mine has) the oil weeps through. He offered to replace it with a turbo engine seal which he said does not have the same design. I suggested a revised 3 seal might be available based on what I read here. Otherwise, I told them to install a new 3 seal.
Thanks to all that posted on this thread earlier. It really helped.
Jim
Jim
