Its official, add me to the RMS leak
#31
Porsche's pretty new to this make-your-own-engine thing. Glad to see they're climbing the learning curve.
#32
I have just started to notice a little drop of oil when I park the GT3 and it looks like the RMS . Mine has just at 1600 miles and I followed the break-in. I have alerted my dealer that it is a possible Rear main seal leak. I will keep watching it. Car was an early July 2007 build.
#33
The interesting thing to me is that the GT3 uses the same crankcase as the air-cooled 911 and has used the same rear main seal design since the late 1970's and there were no issues with leaks in those cars, at least none I knew about.
The negative pressure crankcase ventilation system of the GT3 is supposed to be the culprit. I wonder what would happen if it were disconnected, besides the loss of around 6 HP...
#34
2007 GT3 RMS LEAK
HAD RMS REPLACED AT 290 MILES- CAR NOW HAS 350 MILES AND IS LEAKING AGAIN- DEALER DOES NOT KNOW WHAT TO SAY- I SAY GIVE ME A NEW MOTOR- DEALER IS A LARGER EXPERIENCED DEALER WHERE I HAVE BOUGHT 4 CARS THE LAST 4 YEARS- ANY THOUGHTS????
#35
GT3 player par excellence
two, experienced or not, they MAY still make mistakes. porsche is very experienced but many RMS were installed poorly from factory. and the correctly installed seal actually looks like it is installed the wrong way (that's what my dealer tech told me)
three, how many miles you got on your car? i was told if you dont drive it much, it tends to leak more (not sure if that's true, but i drive mine a lot. only had one RMS replaced when the car was at 2000 miles, it has 15k now. bone dry)
#36
Have any of you installed a rear main seal yourselves?
To screw it up one would have to be totally inept, if one installed it backwards it would not work at all and IMMEDIATELY on start up the engine would hemorrhage all of it's oil in seconds.
#38
Has anyone had a RMS leak/problem with a 2008 GT3RS or GT3. If my 08 RS leaks I will sell it, I'm not going to deal with this problem again, my 996 GT3 leaked twice and I ended selling it for a big loss. Might be an opportunity for someone to buy an 08RS in the future, I really hope it won't happen cause so far the car is great.
#39
You might do a search hear and over at 6speed. I thought i recall someone had RMS and had to go back several times and Porsche made the call to replace the motor, That is what I recall i would find the post. At some point most you would have leverage under you state or federal lemon laws to get them to replace the motor or fix it correctly but I suspect you would have to give them 3 chances to get it right. When and if the time comes, you have to deal with the Porsche representative if your deal does not advocate with you. Your dealer has no ax to grind and they do not get dinged for it but some are better than others in taking care of the customer.
#40
forgot to tell you al, when we replaced the LWF, my baby also had a RMS seal drip problem. So he replaced the seal while he did the LWF, free of charge since the RMS is still under warranty, got lucky. I will see if it is leaking again at the end of this weak. My car5 had right around 3300 when it had a good leak. Brian
#42
Here's my theory based on the facts that:
I think the oil from the galleries above the crankshaft can drain past the main seal after shut down because the negative pressure inside the crankcase is enough to overcome the force of the rear main seal's circumferential spring thus allowing oil to "burp' past the RMS as the pressure inside the case equilibrates with atmospheric pressure.
My $.02 theory.
- The oil only appears after the engine is shut down and does not seem to happen with the engine running
- Normally when the engine is running, the seal is held in contact with the crankshaft by the pressure of the oil behind it and by a circumferential spring when the engine is not running (no oil pressure)
- The oil galleries in the crankcase are above the centerline of the crankshaft and store a significant amount of oil
- There is residual negative pressure in the engine after the engine is shut down due to the effect of the one-way valve in the GT3's crankcase ventilation system
My $.02 theory.
#43
I thought that the RMS leaks were overwhelmingly affecting the Carrera/Boxster engines due to the lower torsional rigidity of the block ?
I also thought that the RMS designated the crank seal at the connection between the block and the gearbox, while the picture above shows the crank case ? Can anyone shed some light ?
#44
negative crank pressure is not going to equalize thru the rear main seal. If it does, the seal is useless and should leak like mad when the engine is running and there is actual blow-by to deal with. I find it amazing this is still an issue. I have not heard of a single GT1 based 997tt having a RMS leak. This includes cars running 18# boost and redlines raised to 7300rpm. The leak issues should be far greater on the turbo cars with their positive pressure crankcases if it is a block problem. Are any of these leaking cars using LTW flywheels or LTW crank pulleys? Sometimes the harmonic balancing of the crank can be thrown off on the higher orders. If a particular someone starts chiming in on the pitfalls 0W40 oil I will scream.
#45
Are any of these leaking cars using LTW flywheels or LTW crank pulleys? Sometimes the harmonic balancing of the crank can be thrown off on the higher orders. If a particular someone starts chiming in on the pitfalls 0W40 oil I will scream.[/QUOTE]
I can speak for myself my car was all original. I have paid attention to most posters, if I had to guess most people installed the LWF if at all, after they found a leak and did it when the motor was pulled. The explanation that I have read by posters that makes the most sense to me is either a defective ring seal or defective installation of the seal at the factory. The design of the motor is solid. I do not recall anyone with a 997 tt complaining or a leak but I don't read the posts on that side either.
