Need "Slick "size verification
Looking at running Michelin slicks on the 996 GT3. The suspension is now complete as well as the new transmission gearing. I just need to clarify the correct size slicks to run? I have been told that the Cup tire size will not work on a standard GT3? 24/64-18,27/68-18 I suspect it has to do with gearing (ring & pinion) and the ECU? Any suggestions.
P.
P.
The cup sizes will not work because of the ABS on the 996 GT3. I THINK they will work on the 997 GT3 though. If it is in fact a 996 GT3 that you need them for then:
Michelin 24/64-18 fronts and 27/65-18 rears (Not sure if these are available anymore). Check with JD Motorsports
Pirelli 245/645-18 fronts and 305/645-18 rears
Yokohama and Dunlop also have comparable sizes - check with Bob Woodman for the Yoks and Pirelli's
Sasco has the Dunlops.
