Cold tire pressures at Mid-Ohio
Any recommendations on cold tire pressures at Mid-Ohio? Will be my first track event in the GT3. Car has MPSC. Front bar is in the middle hole, rear is in the rear hole. Temp is predicted to be 42 to 55 degrees. Everything is stock. I have about 15 schools, almost all at MO. Last car was a 996 turbo cab in which I ran about 1:50 on street tires. TIA.
I will start 1-2 pounds higher than usual, that is 25F 28R instead of 23F 27R. I expect to have to remove air by the end of the second session. The goal is 32F-36R. That's for the RS with the MPSCs. See you there!
