new GMG center section
Just got my new center section pipe from GMG all pumped to install tonight for track weekend!!! BUT no exhaust clamps sent with it... said they were on back order will ship out asap!!!!!!!!!
oh well we will wait!
maybe you can use the oem clamps. pipes should be the same size as oem.
if you are changing just the center section, the stock clamps have to fit...they just will not be as shiney....shim/sleeve them if you have to to account for any diameter differences.
Needs to Get a Life
Here is a pic. Maybe you can cut one of these out of the pic and use it. Just kidding. That really stinks. Hang in there...you will love it.
Guys, I posted this on the other thread and don't want to hijack but since you're installing these make sure you swap out the stock header bolts for some 997tt stainless steel ones. I'm working at getting some of those on every kit we send out with ours if I can. You have to remove the cats/headers to be able to install both ours and GMGs (or any center section) so it's well worth the few bucks...
Do you have the part # for the TT header bolts? I would put anti-seize as well then.
Thanks Alex.
**Edit** Looks like they are M8x26 (18 needed; torque to 17ft-lb or 23Nm). The diagram below shows the torque sequence for the header bolts. The GT3 headers have 9 bolts per side vs. the 997s as shown below. Just torque from center header outwards.
