FVD USA is Proud to be a New Rennlist Board Sponsor - GT3 / RS Flashload & Exhausts
FVD-Brombacher is happy to introduce our new flash load ECU upgrade, making do-it-yourself at home ECU tuning for all late model Porsche vehicles a reality. In conjunction with our Flash load programming roll out, FVD has 997 GT3 & GT3 RS Flash Load programming for $1,595. Our Windows® based software is a simple, computer guided experience that requires hardly any user input and little more than a computer with an internet connection. Our program allows users to input performance upgrades already installed on the vehicle which enables FVD-Brombacher to custom tune a program to suit individual requirements. Whether your vehicle is completely stock or heavily modified FVD-Brombacher has a program for you! FVD-Brombacher’s flash load software also allows customers the ability to flash their ECU back to stock anytime using the same software and supplied cable. FVD-Brombacher also offers program update incentives should the customer decide to step up performance with one of our level kit options. Level kits are companion parts designed to work seamlessly in concert with our tuning software to maximize your Porsche’s performance. Contact FVD-Brombacher for further information regarding our programming or any of our vehicle specific level kit options and find out why more and more enthusiasts choose to put our passion into their Porsche!
997 GT3/RS - LEVEL 1 Tuning
Kit includes:
Software Upgrade 997 GT3/GT3RS (FastLoad) and a BMC Sport Air Filter
Stock:
Max. Power - 305kW (415HP) @ 7600rpm
Max. Torque - 405Nm (299lbf ft) @ 5500rpm
Max. Speed - 310km/h
Max. RPM - 8400rpm
Acceleration 0-100km/h - 4.3s
Tuning:
Max. Power - 314kW (427HP) @ 7500rpm
Max. Torque - 420Nm (310lbf ft) @ 5500rpm
Max. Speed - 315km/h
Max. RPM - 8700rpm
Acceleration 0-100km/h - 4.1s
![](http://multimedia.fvd-web.com/6speed/cable2.jpg)
![](http://multimedia.fvd-web.com/6speed/level1.jpg)
997 GT3/RS - Level 2 Tuning
Kit includes:
Software Upgrade 997 GT3/GT3RS (FastLoad), BMC Sport Air Filter and Sport Exhaust System
Our exhaust systems gives the 997 GT3 a more pronounced, aggressive sound similar to the 997 GT3 Cup Car with much more of a growl. This exhaust is much less restrictive than the factory version which produces more power and a great sound!
Our Performance exhaust with side mufflers and center collector features:
· High Quality T316 Stainless Steel Construction (Increased corosion prevention over T304).
· Highly effecient German Tri Metal 200 Cell Catalytics which flow like 100 Cell
· Utilizes exhaust valves so your sport button works like factory with much more sound!!
· The Muffler will not crack due to the extreme high heat due to our advanced mesh integration.
· This System Weighs 42lbs and is one complete unit. The headers are welded to the cats to allow for the perfect backpressure to produce good torque down low. This system produces 20HP and 20 lb. ft of torque (with an FVD software upgrade).
Reuses Factory tips or any other aftermarket tips that fit on the stock exhaust
Stock:
Max. RPM - 8400rpm
Tuning:
Max. Power - 320kW (435HP) @ 7500rpm
Max. Torque - 430Nm (317lbf ft) @ 5500rpm
Max. Speed - 320km/h
Max. RPM - 8700rpm
Acceleration 0-100km/h - 4.0s
![](http://multimedia.fvd-web.com/6speed/gt3sportexhaust.jpg)
![](http://multimedia.fvd-web.com/6speed/level2.jpg)
Last but certainly not least is FVD- Brombacher’s Race Exhaust
Video: http://youtube.com/watch?v=WizXsz_StrE
Our "Race" exhaust features side muffler bypass and flows directly into the end collector. This exhaust is side muffler delete offering a further reduction in weight, nearly 16 lbs compared to our performance system and incredible sound. The system features:
· High Quality T316 Stainless Steel Construction (Increased corrosion prevention over T304).
· Highly efficient German Tri Metal 200 Cell Catalytics which flow like 100 Cell
· This System Weighs 26lbs and is one complete unit. The headers are welded to the cats to allow for the perfect backpressure to produce -good torque down low. This system produces 25HP and 25 lb. ft of torque (with an FVD software upgrade).
· Reuses Factory tips or any other aftermarket tips that fit on the stock exhaust.
![](http://multimedia.fvd-web.com/6speed/fvdrace.jpg)
5% OFF for all Rennlist Members
FVD-USA
Toll Free: 1-800-274-2220
Fax: 954-977-7650
Email: info@fvd.us
Visit the WORLDS LARGEST Porsche Online Shop at www.fvd.us for over 35,000 parts!!
US DISTRIBUTOR for Fuch's Premium Exhausts, and Trickstuff Brake Pads!
Kit includes:
Stock:
Max. RPM - 8400rpm
Tuning:
Max. RPM - 8700rpm
Kit includes:
Stock:
Max. RPM - 8400rpm
Tuning:
Max. RPM - 8700rpm
FVD-USA
Fax: 954-977-7650
Email: info@fvd.us
GT3 player par excellence
i have dealt with ronda before. unlike many other aftermkt shops, she is very prompt and gets your the answer right away and knows the products well too.
