Anybody installed Recaro SPG ?
GT3 player par excellence
Originally Posted by David A
Thanks for your help Mooty,I will try the Pole Position,I'm 5'9 and 33 waist.
you will fit spg also, but EVERYTHING will feel numb after 45 min of driving, when you stumble out of the car.
Originally Posted by rsman
Will the 996 Euro GT3 seats fit the 997 GT3, and if so, are there any required modifications to make that happen. My dealer says they won't fit but I'm not sure that is the case. Any fedback would be most appreciated.
i have 996gt3 euro seat in my 997gt3 RS.
they bolt right in.
you need to turn off the thorax bag warning light and AWS light on the center console.
the prodedure has been posted many many times. you can search under my handle.
Just installed Recaro Profi SPG XL seats in my 997 GT3, in conjunction with a DAS "weekender" half-cage and Schroth PII-6H belts.
The seats fit my 6'2" 215#, 40" waist, 33" inseam bod just fine. In fact, I have to set the seats two notches forward of the max rearward position. Be advised that the OE 3-point belts are history, as they can't be made to function with the Recaro mounts.
Be sure your vendor ships the correct brackets and sliders.
Comment: My seats came in nylon velour, which picks up every piece of lint within our tri-county area! A Helmac lint pickup or lots of 3" masking tape helps. Suggest ordering leather instead of the mouse fur nylon velour!
oem belt can be used with ANY seat.
