Finished Clubsport Package
#31
Basic Sponsor
Sorry, but I don't have the breakdown of everything. If I had to guess, it would a slight weight loss. I kept my old seats and they are extremely heavy. Add back the bottle and cage and we're probably close to original weight. However, I believe they have a scale at RRR and I'll be attending at the end of Sep when I get back in the country. I'll be happy to get a weight with a full tank and give you an update then. If you will, get a weight on your car with a full tank with the original equipment and we'll compare.
![](https://rennlist.com/forums/signaturepics/sigpic53041_8.gif)
The apex of performance, comfort & safety since 2011.
All new racewear available now→ traqgear.com
#32
I did some quick weights on the conversion. Done on a bathroom scale so please forgive me if it's not totally exact.
The stock seats with rails weighed 48lbs apiece X 2 = 96lbs
The Carbon Seats with Pads, Rails, and Seat Adapters weigh 21lbs apiece X 2 = 42lbs
The RS Cage with paint weighs 37lbs
Scroth Harnesses with all the hardware weigh approx 6lbs
B&K Sub Bar with B&K Extinguisher Mount + 2.5LB Amerex Halon Fire Extinguisher weighs 17lbs
So it ended up adding 6lbs overall once everything is installed.
#33
Basic Sponsor
#34
The October issue of Car & Driver has a short review on the RS. C&D shows a total weight of 3,180lbs on their test car that is equipped with PCCB's, Nav, Full Leather,Bi-Xenon's, & Chrono.
Should hopefully have mine on the scale in about 2 weeks to compare.
