Any problems with sound limit at LCMT ?
Thankfully, she wasn't hurt (neither was the 944 driver), but she got a good fright. When we were talking to her at lunch, she said she saw the car coming and didn't know which way to run so she hit the dirt and then the car hit. Apparently a car hitting a guard rail is really loud when you are lying behind it.
As for the sound, apparently it was the higher pitched cars that were getting dinged the most so that GT-3 "wail" wasn't helping.
I remember seeing your car at the event. Very nice. White is the fastest color.
I turned the sport mode off after being black flagged.
I've had 4 events at Calabogie and this is the first time there has been a problem with sound.
thanks. white is absolutely the fastest color regardless what others might say
Originally Posted by doc2s
thanks mnorek. how was the gt3 at tremblant?
The 996 GT3 was fantastic. Not that it needed it, but since I was putting in PFC-01 pads, I asked Conway to put in the PFC floating rotors per Jim H.'s advice. The car was perfect. The only thing that needs work is the nut behind the wheel. With very mild camber -2.1, my tires temps were hot on the inside. Since pressures were good, and since I know I was not aggressive on corner entry, it's pretty safe to say that overbraking is the problem there.
My fast lap was my best ever at the track but I am guessing that there is another 5 seconds out there (with lots of practice) since I was errr...slow in areas.
A 997 owner kindly let me drive his car for a session (thank you J!) as a test drive for the 997 (mine was completed last week and is awaiting loading). Very nice. The 997 GT3 is gorgeous inside and out and while I took it easier than I would with my own car, it is very nicely set up as delivered (fair amount of understeer, but OK for learning the car). I had the e-nannies on and suspension soft but with the exception of some very slight wallow, the little bit of lean allowed nice feedback. I cannot believe Porsche delivers those tires with the car, they are impressive.
Originally Posted by Racerron
Orange or yellow are fastest of all.
FWIW, I'm sitting on the balcony of a condo at the Wyndham Cap at Tremblant and I can hear the track. It's not as loud as the birds except for one car (sounds like a cup car) that's just too loud and it's been running for the past two days.
Porsche paints all cup cars white for a reason Besides, I hear that orange cars plow like farm tractors
