What do you think of Volk Racing TE37 rims?
I very much wanted to get set of these wheels but found out that the rear spokes are flat face instead of being convex. I guess the reason is due to the high positive offset that makes it almost impossible to design convex face.
I hv been quoted insanely cheap price for such wheels, white in color.
Too bad but I will still think consider it
Cheers
Cheers
Needs to Get a Life
Sorry for the dumb question but what do you mean the 18" do not come in the right width for the 997 GT3? Do you mean in terms of how it looks on the car or the fit for 18" performance tires?
GT3 player par excellence
Needs to Get a Life
Thanks Mooty. Now I really feel dumb. I looked at the numbers 5 times and just did not see it. Good thing I am not an accountant.....
here's a video of Ray's Wheels forging process;
http://video.google.com/videoplay?do...arch&plindex=0
Breakthru (04-08-2023)
Originally Posted by eclou
11" is well within the allowable bead width for a 305 rear tire. There is no reason you could not use that on the RS with a spacer, and would even save a ton of rotating weight.
but some may want to run larger than 305.
that said, conceivably you can get 13 inch to work if you spend enough time rolling fenders and work out custom offsets.
i just wanted to point out that "technically" the wheel in question is not MADE for the 7gt's.
Volk make the wheels for the Williams Formula One car. Aside from OZ and BBS, not many other wheel manufacturers can claim that.
Ok, so the TE37's are not the same wheel you get on a Williams F1 car... but it must say something about the expertise of Rays/Volk and the quality of their products, that they're found in F1...
Originally Posted by Jon70
Volk does make a 12 inch wide wheel specific for the 997 GT3. No RS fitments though.
i like volk wheels.
They make a 12" wide for a 19" wheel. Largest for an 18" is 11" wide. i was looking at these because they are light! But going to an 18" wheel, so not wide enough. Probably going with CCW now
