997 GT2/GT3 Forum 2005-2012
Recommendations for wheels for 18" MPSCs
Old 06-21-2007, 10:09 PM
Edwin
Edwin's Avatar
Originally Posted by Bob Rouleau
tire rack has an amazing deal on OZ Superleggera wheels mounted with 18 inch 235/315 Michelin Cups and pressure sensors. Very nice price.
I didn't find this on the tire rack site....the cups didn't show up as an option. Is this still available?
Old 06-21-2007, 10:23 PM
str8ner
str8ner's Avatar
I have tried MPSC 235/315 in 18" In my opinion it is too much rubber in the back or not enough in the front. Made the car understeer. May be I should use a lot less pressure in thr front to compensate. You may need to squize a 265 in the front but I do not think that they would fit. Unfortunately that is the next size above the 235. 245/315 18" Hoosiers felt a lot better balanced. I used them for one day. if you are interested I would consider selling them.
Has anyone tried the proxes RA1?
Old 06-21-2007, 10:31 PM
Edwin
Edwin's Avatar
What would be the best tires sizes for 18" MPSC?
Front: 235/40-18
Rear: 295/35-18 is recommended by tirerack for MPS....I can't find the cups on tirerack for 18's.
Old 06-21-2007, 10:54 PM
str8ner
str8ner's Avatar
You can try the 295/30. They actually work out pretty well. The car feels pretty well balanced. It will slightly change you gear ratio. Next step is the 315.
Old 06-21-2007, 11:44 PM
TripleM
TripleM's Avatar
Originally Posted by Jon70
As much as I like Volks, I don't think they make a 12 inch wide wheel.
They do now but only for 19in TE37
8.5 ET+52 , 12 ET+65, perfect for GT3..ie 1mm wider in the front and 3mm wider in the rear.
http://www.rayswheels.co.jp/indexe.html
http://www.rayswheels.co.jp/cgi-bin/...odelName=TE37P
Old 06-22-2007, 12:01 AM
Bob Rouleau
Still plays with cars.
Bob Rouleau's Avatar
Try a PM to damon@tirerack.com he frequents these forums. Good guy
Old 06-22-2007, 08:40 AM
mitch236
mitch236's Avatar
It would be nice if a 265 would fit up front but it won't without some modifications. I like the 235,315 combo personally. I don't think it makes the car understeer any worse. Going to a 295 in back won't make the car have more grip, quite the opposite so I would use 315's and adjust the suspension. Springs come to mind and GRussel (I think that's his handle) is doing some research for us now.
Old 06-22-2007, 09:41 AM
Edwin
Edwin's Avatar
mitch236...have you run the 235,315 combo already on the 997GT3? If so, why change the suspension?....thanks.
Old 06-22-2007, 12:16 PM
Ray G
Ray G's Avatar
Originally Posted by grussell
Yeah, you are right...
OMG, that looks fantastic! I thought I was looking at a cup car at first.
Do you have any problems with rubbing while steering? I know the race car has a limited steering lock.
Old 06-22-2007, 12:54 PM
mooty
GT3 player par excellence
mooty's Avatar
Received 5,692 Likes on 2,339 Posts
if you think garret's car looks good in pix....
i saw it in person at button willow. words dont do it justice.
the cup car bumper, euro rear bumper, fat hooters on bbs with big camber....
oh, and no sunroof ;-)
grussell
grussell's Avatar
The best I fitments I have found are:
Pirelli Slicks 245/645-18 & 305/660-18
Hoosier Grand Am GT 245/645-18 & 295/660-18
Toyo RA-1 245 & 305
all work well on 9" front and 11.5" or 12" rear.
Old 06-22-2007, 01:02 PM
grussell
grussell's Avatar
Thanks! I am loving this project!
Will you be at Willow next week? I will be trying out the new 900lb springs and sway bars.
Old 06-22-2007, 01:05 PM
mooty
mooty's Avatar
no, i rarely make it as far south as willow (willow springs, i presume). last was 2004.
i will be at buttow willow tomorrow and sunday.
can you pm me where and how much those bbs are. also offset info.
9 and 12"?
Old 06-22-2007, 01:19 PM
grussell
grussell's Avatar
My BBS are:
18" x 9" ET53
18" x 12" ET64
You can order them from Fabryce or James at GMG
Old 06-22-2007, 06:16 PM
Jon70
Jon70's Avatar
Too bad no rear fitment for the RS though.
Quick Reply: Recommendations for wheels for 18" MPSCs
