Understeering RS and GT3
#31
Still plays with cars.
Hmm, it looks to me like the car understeered on initial turn in, (turn, turn much more) then a lift off the gas to rotate (over-rotate) the car. Nice car control though.
#33
GT3 player par excellence
Originally Posted by NOBLEGT3
the Exige S would eat it alive even if it wasnt understeering...was at mosport on wednesday and this car ****ING ROCKS...i couldnt believe the acceleration down the long straight as couldnt many others in F430,Viper,Radical...who commented " man that thing has grunt" i still havent learned to drive the car yet ( braking 100 ft later is hard to trick your mind into) and when i get the boost turned up it will be unstoppable...best supercar avaiulable .
if you are at the track with me come and try it.
i dont even have the track pack only stock suspension....i cant imagine how good it is with ohlins or nitrons
#34
Originally Posted by mooty
THINK dont brake, and you will brake late enough to be fast ![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
I think Moot is saying braking in the little Lotus is like mixing the perfect Martini, you don't add Vermouth, you just think about it and that's enough.
#35
Originally Posted by grussell
Does anyone have the ride height specs? Is there a Min - Max?
#37
^ Thanks! Where did you get those specs? Are they from Porsche?
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
#38
Originally Posted by doc2s
bob,
less toe in at the rear improves rotation at the expense of high speed stability especially under braking. if 32' rear toe is total then it leans towards stability. if per wheel then its a lot. good luck with the setup and keep us posted.
Note that this is basically the 'circuit' set up in the manual except that I have 0.3 deg less camber in back and a half degree more in front. Now looking for some 18 inch wheels!
Best,
#39
Best,
Best,
#40
Doc - it is my understanding that toe in at the rear also helps to rotate the car. I went zero in front and 16 mins a side in back. Neg 2.5 in front, 2.0 rear. Rotated the struts and caster is 8.5 deg. It worked he car handled very nicely. No oversteer and just a smidge of understeer. Felt the same as my 996GT3 only I was a second a lap faster. Considering the N spec tires have less grip than the 18 in Cups, I was pleased!
Best,
Best,
#41
I don't understand the bitching about "out of the box" understeer. What street 911 from the factory has not understeered for the past 30+ years?
Nice vids earlier.
Nice vids earlier.
#42
Bob, the 18" MPSCs are smaller diameter than stock I think. You can run Toyos in near factory diameter. I think Noble had some issues when he went to the 18" MPSC setup on his 997S. Food for thought.
Stock
235/35-19 25.5"...............................305/30-19 26.3"
RA1
245/40-18 25.6"...............................305/35-18 26.3
275/35-18 25.5"................................335/30-18 25.9
PSC
265/35-18" 25.2"...........................345/35-18 26.2
235/40-18" 25.4"...........................295/35-18 25.2"
....................................................315/35-18" 25.5"
Hooters
P245/35-18 24.7"...........................315/30-18 25.6"
Nitto
245/40-18 25.55..............................315/30-18 25.35"
Stock
RA1
PSC
Hooters
Nitto
#43
Frayed - next week I am going to borrow set of 996 GT2 wheels with 235/315 18's. Front and rear diameters are very close to each other, but I am worried about the rears being 0.8 inches less than the 19 inch N spec. The fronts are "close enough" in diameter between the 18 and 19. I hope Noble will chime in here.
Best,
Best,
#44
Best,
Best,
great that you got the setup sorted out and that the car handled well. my experience with rear toe for mid/rear engine is that you need toe in for high speed cornering/braking stability at the expense of straight line speed and rotation. with a front engine car 50/50 weight dist. like a spec miata i use zero toe in the rear in favor of more roation since top speeds are "low" and not much braking is needed. my 2c.
#45
Originally Posted by cleanme
What about those Dymag rims that are carbon fibre&magnesium? They're frickin light but standing up to track duty? I'm not sure.
