GT3 RS Green Brembo Brakes
My friend, Scott wanted PCCB's but was too late with the decision, so here is what he and Chris @ C2 Design in Tampa came up with!!!!!!
The matching green calipers are for real - no photoshop action.
Just saw today - amazing in person and FYI - we are boxing up all factory parts for the purists etc.... can always be put back to stock for resale.
Originally Posted by volpenyc
So why are the tail lights removed?
Originally Posted by SA Mike
Man that is too cool! I have a Signal Green 94 Turbo. Ask your friend if they can do them in Signal Green.
Thank You
Originally Posted by RMN22AJR
No problem any color possible - Chris's number at C2 is 813.223.3744
Originally Posted by nkhalidi
So your friend bought a whole nother set of calipers just to repaint them green?
They look good, I like it. Thanks for posting.
Originally Posted by Max Power
^^^ great question. How about a pic of it on the ground?
Thanks!!!
Thanks!!!
The Brembo weights are:
1M1.9007A – Front 380mm 6 piston Monobloc front kit.
Front 380x32mm rotors 18 lbs
Front 6 piston Monobloc caliper 7.8 lbs.
Front pads for 6 piston Monobloc caliper 3.2 lbs.
Total 29 lbs.
2P1.9005A – Rear 380mm 4 piston Monobloc rear kit.
Rear 380x28mm rotors 15 lbs.
Rear 4 piston Monobloc caliper 6 lbs.
Rear pads for 4 piston Monobloc caliper 2.6 lbs.
Total 23.6 lbs.
Does anyone know the weights of the factory steel brakes?
Total 29 lbs.
Total 23.6 lbs.
Total 29 lbs.
Total 23.6 lbs.
Total 29 lbs.
Total 23.6 lbs.
Just weighed factory parts on our scale at C2 Design in Tampa.
Factory 350mm Front Steel Rotors 24lbs.
Factory 6 piston Calipers with pads 11lbs.
Total Front Weight 35lbs.
Factory 350mm Rear Steel Rotors 21lbs
Factory 4 piston Calipers w/ pads 9lbs
Total Rear Weight 30lbs
