997 GT2/GT3 Forum 2005-2012
Pirelli Corsa? Break-in procedure
Old 04-05-2007, 01:12 AM
SoCal Craig
SoCal Craig's Avatar
Default Pirelli Corsa? Break-in procedure
Picked up the car yesterday morning. Just noticed it had Pirelli P-Zero Corsa tires. I thought they were supposed to come with PS Cups?
Also, is everyone doing the full recommended break-in... 2K miles not exceeding 4200 rpm?
Finally, FWIW... I like the sunroof
Old 04-05-2007, 01:16 AM
frayed
frayed's Avatar
Luck of the draw on tires. No worries, you'll wear them out in short order.
Break in: That's the subject of flame wars on boards of every make, from sportbikes to hyundais. Me? I'm following the manual strictly.
I will say, however, that whatever path you follow, do it only after the oil and water are up to normal operating temps.
Cheers.
Old 04-05-2007, 04:35 PM
dan360
dan360's Avatar
Good luck, Pirelli Corsas are what I have on my CS, they're great tyres but as said before you will wear them out in short order
Two pieces of Corsa advice:
1) Wear them in before hitting the track (or have them shaved). They will "chunk" on the track if you hit it with a brand new set and one track day will kill them.
2) Cold Weather (< 45F) and Corsas do not mix. I see you're in CA, so this is like'y not a problem for you.
Old 04-05-2007, 04:42 PM
SoCal Craig
Thanks for the comments on the Corsas. I've never driven on them before. While the car will see some track use, most of the time I drive a Radical SR3 to get my jollies.
Old 04-05-2007, 04:59 PM
dan360
dan360's Avatar
rather faster lap times than the GT3
Quick Reply: Pirelli Corsa? Break-in procedure
