I weighed the RS today
#46
JFT we are all grateful for the info you provided and we all hope your figure is accurate it's just confusing..you should be happy anyway because you have the lightest possible version a ROW RS
thanks ChrisGB
thanks ChrisGB
#48
In the Excellence article, when the car's fluids and fluid weights are discussed, it is mentioned that the Air Conditioning coolant weighs 20 kg. If you delete or remove the A/C hardware, you would also delete an additional 20kg of fluid.
So the A/C could be considered a 40 kg (88 pound) option.
