997 gt3 rear diffuser
#31
Here are the 7GT3 underpanels on my 996. The diffuser will tie in with the rear triangle and cover the whole underside of the whole engine all the way to the rear bumper. This is pretty much exactly what Porsche did with the 997GT3R which used the factory 997GT3 underpanels.
#32
Very cool thx for the info. I already have all the 997 panels except for the last one with the naca duct. I would just have to check clearence with my fvd center exhaust. I think the muffers would be fine but the header might drop down too far?
Ill put this on my wish list for next winter.
#34
They did a real nice job integrating that. Similar to what we are doing except we opted to have the diffuser with a curved profile instead of flat.
#35
How does this impact heat dissipation from the engine compartment? Seems like it may block a lot of air circulation, which I know is good for aero, but is it ok for heat? Would this be ok to use for street use where speeds are typically much lower than on the track (i.e. traffic)?
#36
#37
#38
Here's to hoping it clears with a Dundon setup...
#39
I honestly don't see why this would be necessary on a street car, maybe in Germany where you can often see deep triple digit speeds. This is more of a track mod to improve downforce and airflow efficiency. This is why you see this employed on all the Porsche motorsport applications now. Regarding cooling, that won't be an issue as these cars have so much reserve cooling capacity to begin with and hot air is continually extracted via the decklid fan which the Cups / RSRs don't even have. Keep in mind the diffuser is not air tight.
#40
certainly not necessary for a street car. My question was more for cars that serve double duty since I Imagine most owners here don’t have a dedicated track car. Is there a downside from using this is on the street. The deck lid and fan push air in, they don’t extract heat. Heat is extracted through the bottom except for when car is parked and fan not running then heat radiates up and through the fan inlet opening. I think you answered my question though, seems like this is a track specific mod.
RAudi Driver (04-18-2024)
#41
Rest assured, cooling won’t be an issue. There is plenty of room for air to get pushed out on either side of the diffuser. Keep in mind the vast majority of engine cooling is handled by the radiators and not the tiny bit aided by the decklid fan. For a dual duty street/track car this would be a great addition in my opinion.
#43
Cool to see new parts still being developed for these cars!
#44
@powdrhound any updates?
kk2 (05-08-2024)
