MCS
Hi,
I recently picked up gen 1 MCS 2 way suspension with compression and rebound adjustments for my 996 turbo.
Current setup:
150 PSI front and rear canisters
700# springs in front
900# springs in back
compression, 12 in front, 12 in rear
rebound, 15 in front, 16 in rear.
The car is setup primarily as a track car. Rear wheel drive with a guards LSD pushing about 600 wheel HP at 1.5 bar. When at speed it feels a little soft / bouncy in the the turns when there are undulations. Is anyone familiar or have suggestions with MCS suspension settings?
Thanks! Karim
Current setup:
Thanks! Karim
Can't do much about the springs but you could try dialing down your rebound and compression. Bont front/rear: rebound 8, compression 4. I'm running 180 psi front/200 psi rear canister pressures.
post in 996 turbo sub forum. good luck, sounds like a nice turbo
Sounds like a great setup. I have gen 2 3way setup with similar springs. Your 2way should be the exact same thing with w LSC set to 5 and no adjustment.
i Would recommend calling Wyatt at MCS, he is very knowledgeable and open to sharing all his info..
ultimately spending a few hours on an empty road or track playing with settings is the way to get things dialed in…
with that said, here are my settings for reference:
_______________________MCS settings...
Road Trip:
150 PSI all around...
Reb
F-3
R-5
LSC
4 F&R
HSC
R-5
F-3
Street
Rear
Reb 0-15
5f
7r
LSC 0-5
5, lots of mass to control....
HSC 0-14w
9r
7f
Track
Rear
Reb 0-15
7f
9r
LSC 0-5
4, lots of mass to control....
HSC 0-14
10r
8f
Road Trip:
Reb
F-3
R-5
LSC
4 F&R
HSC
R-5
F-3
Street
Rear
Reb 0-15
5f
7r
LSC 0-5
HSC 0-14w
9r
7f
Track
Rear
Reb 0-15
7f
9r
LSC 0-5
HSC 0-14
10r
8f
Road Trip:
Reb
F-3
R-5
LSC
4 F&R
HSC
R-5
F-3
Street
Rear
Reb 0-15
5f
7r
LSC 0-5
HSC 0-14w
9r
7f
Track
Rear
Reb 0-15
7f
9r
LSC 0-5
HSC 0-14
10r
8f
Road Trip:
Reb
F-3
R-5
LSC
4 F&R
HSC
R-5
F-3
Street
Rear
Reb 0-15
5f
7r
LSC 0-5
HSC 0-14w
9r
7f
Track
Rear
Reb 0-15
7f
9r
LSC 0-5
HSC 0-14
10r
8f
