Front Fender Liner 997.2 RS
I’m looking to replace the front left fender liner on my 997.2 GT3RS (the panel in front of the wheel with the radiator hole).
It looks like the part number is 997-504-123-93 based on the parts diagram but I’m not positive bc the part number is the same for the .2 GT3. RS has wider front fenders w those extensions which is why I’m hesitant to order. Can someone confirm if this is the right part number?
nle (03-15-2023)
For the piece you’re referencing, RS and standard are the same. .1 and .2 are different. Worst case you should be able to pull the current part that is on there (unless it’s missing) and check if there’s a part number on it.
nle (03-16-2023)
Thanks guys!
You won’t like the price 997-504-124-93 $435.89 from dealer… I found one online for 250… then I decided to just wash the existing one, run a torch on it to smooth it to new, JB weld the little spot that had worn through and sanded it down lol good as new lol.
stupid price unless your ready to retire it to a show car imo
Btw that’s right front
^ this is genius! I’m going to give it a try!
lol the JB weld black body panel adhesive is what I used...it dries gloss so I shot it with a can of black trim paint lol, also did a few 'tests' as it kinda likes to droop while drying. Not that anyone will ever see it but I will eventually buy a brand new one for when the car retires.
