This is in regards to a pair of coolant hoses that run in parallel.. guessing one is feed and one is return.. up to a front radiator. There is a hard line portion that runs under the transmission and then it goes back to soft and make a 90 degree into another set of hard lines.. one of the hoses is leaking at the transition back to hard.
Wondering if somebody can help me identify a part number for these two soft coolant lines.
Anybody else see this? Coolant lines on the engine are pinned on this car and this is the first real issue that has come up.
You can see where the hard line hanger has fallen off the mount.. guessing that's what caused this.
