RS with Öhlins TTX (lift delete)
Hello guys
I have an 997.2 GT3 RS, OEM with front lift.
Soon it will have Ohlins TTX. 😇
I don’t find any info about front lift delete, the few lads that have aftermarket coils and lift OEM, how have you done?
dismount the whole lift system including compressor? Coding etc?
sorry for my english, best regards from 🇸🇪
Hello guys
problems with codes/warning lights etc?
My car just had the system removed in PIWIS so that the button did not function. The physical system it self was left in place in the car. I would make sure all the lines are well plugged if you do.
Yes, coding is the easy way. ☺️
Done that before but this time I would like to do deletes. So I easy can go back to OEM. 😅
If I take the whole system out, the unit is placed in the tunnel under the cockpit I think. How would the electronic react? 🤷♂️
I have my car with the FAL module entirely removed. I have no issues/error messages because I coded it out. Before I did that I had "Lift" errors because my system was broken (no current would flow to the motor and pressure switch would not switch). This would result in a "Lift" error message on my dash. I think you can safely remove the system and not have any error messages as long as you don't press the button or if you code it out.
If you are looking to sell your lift module let me know. I have low confidence I will be able to repair mine.
