Refurbished PCCB 2010 PHOTOS
Hi guys, just want to show you how refurbed discs look like for 997 GT3.
Values using Carboteq are significant better, also the weight went from 4662 g to 4678 g.
Ct (before) 65,5 60,2 60,8 61,5
Ct (after) 79,1 71 71,9 76,4
Before REFURBISHMENT
After REFURBISHMENT
After REFURBISHMENT
Redisc (02-11-2023)
Redisc (02-11-2023)
Basically (shave it, soak it in a chemical to break the bonds, soak/bond the new "spongy carbon disk" it in new carbon compound, bake in oven till crispy brown) and repeat until desired Caroteq readings.
So my refurbished disks are actually .1 mm thinner and 15% denser
So moving forward there is no way for me to tell if the refurb versions are 'toast' without a weighing (estimating) or a Carboteq and comparing to the readings ReDisk provided me.
The reason Surface Transforms are refurbish-able is that they do the same process but they start your disk out wider than OEM (that’s why they need spacers). So they advertise enough material to do the process 2-3 times, the OEM disks are prob one-shot deal. Hence why I’ll still track my other ones.
The following 2 users liked this post by Wonderdan:
RAudi Driver (02-11-2023),
Redisc (02-11-2023)
One of the advantages is, that discs have received an OXY coat, which prevents air from coming inside the core and also prevents "evaporating" carbon fibers. An oxy coat is put on the edges.
If anyone has any technical questions, I was thinking to make a video call / presentation and there you can asks me whatever you want to know.
Is anybody interested?
Thanks Maya
Thanks Maya
fayraree (02-13-2023)
https://rennlist.com/forums/showthre...errerid=249869
