350mm to 380mm Steels
Hoping for an easy answer on this one, done lots of searching but no clear answer.
7.1 GT3 want to go from 350 steels to a 380 floating setup.
Is it just a case of buying some brembo/pf/girodiscs and some caliper spacers or is there more to it?
362mm floating rears sounds an easy job with caliper spacers to match, it's just the fronts I'm stuck on!
Rich
Rich
You can get thr PET and compare the .1gt3 to its .1pccb optioned model. The .2 rotors fit ok. My .1 was a pccb car and i have .2 rotors and pads fit fine. It’s the fronts that are different.
In general tho, for front it’s the uprights, calipers, bolts, brake line tubing, rotors. Rest should be same.
GTTommy (09-05-2022)
Rich
Rich
You will also obviously need the 997.2GT3 380mm calipers in order to use the 380 rotors. You can get these in red (steel) or yellow (PCCB). Finally you will want to buy the front brake lines used on the 7.1PCCB car although you can bend the existing lines on the 7.1 steel car. The brakes lines are cheap, about $20 per side.
From a purist standpoint, I would purchase the 997.1 PCCB uprights instead of using the adapters. Will cost an additional $3K however. Don't mess with the rear set up. Keep it at 350.
Thanks for the super detailed responses there!
I didn't realise it would be a new caliper job... I'll price some up, if it's too much it'll be similar to just go for an aftermarket bbk setup?
Kinda screws up my winter project while it was off the road
Powdrhound covered it thoroughly. Yes, unfortunately migrating to larger 380mm discs on the 7.1 iron-equipped car is not cheap or easy. We have some outstanding AP Racing 2-piece J Hook discs in your OEM iron sizes if you do decide to stay with stock-sized discs. Our discs flow more air, run cooler, and last longer than anything else on the market. You can see them here: https://www.essexparts.com/my-vehicl...RS/Iron%20disc
Lots of customer reviews of our products on our blog here: https://www.essexparts.com/news-blog
Let us know if we can help.
'09 Carrera 2S, '08 Boxster LE (orange), '91 Acura NSX, Tesla Model 3 Performance, Fiesta ST
Jeff Ritter
Mgr. High Performance Division, Essex Parts Services
Essex Designed AP Racing Radi-CAL Competition Brake Kits & 2-piece J Hook Discs
Ferodo Racing Brake Pads
Spiegler Stainless Steel Brake Lines
704-824-6030
jeff.ritter@essexparts.com
Jeff Ritter
704-824-6030
GTTommy (09-11-2022)
Thanks for the reply Essex.
I'll be going 380 fronts with the later calipers, no point doing half a job.
For anyone that's been running 2 piece steel rotors on track is there a particular brand that hold up well?
The following 2 users liked this post by nle:
GTTommy (09-15-2022),
SupraSaiyan (09-16-2022)
The front 350 calipers are 100% physically different from the front 380 calipers on both US or ROW cars, both 7GT3 and 7TT. The 350 calipers have 146mm bolt spacing, the 380 calipers 225mm spacing. Even the 380 TT calipers are different from 380 GT3 calipers, the GT3 versions have smaller pistons.
GTTommy (09-17-2022)
