failure oil pressure indicator
I backed my 2010 GT3 out of my garage yesterday and a warning light came on that said "failure oil pressure indicator" and the oil pressure gage read zero. I checked oil level and it was normal. I shut the car off and pushed it back into the garage. This happened about 8 years ago and the dealer replaced the oil sensing unit and all has been good up to now. I made a appt with the same dealer to look at the problem and possible do the same repair. Has this happened to any of you?
No
I've had my 2007 since new; it's never been a problem. You most likely want to hear from folks with a problem though.
i cant help but think that if the dealer replaced the oil sensing unit a few years ago, its less likely you have another bad sensing unit now. You may have a poor or intermittent connection between the sensor and the DME...perhaps at the sensor connector. Something to check at least.
I brought the car to the dealer in July to address the oil pressure indicator sensor fault and also the 12 year service. They replaced the sensor and it worked. I went to pick it up and when they started it up to read the DME the indictor light came on again. I left the car, they took it apart again and found the electrical connector was not properly plugged. It was all put together and tested. I came back to pick the car up and as I drove out of the parking lot the warning light came on again. Left the car. The dealer has given us a loaner car during the whole process and they have been good to deal with and i am sure they are as frustrated as I. Any suggestions?
This may or may not help, but looking back through my service history for my 2010/GT3 and I found a campaign from late 2012 where they had to reprogram the DME to correct oil pressure measurements. Below is what was documented for the service performed on my invoice:
"Performed Campaign WC08 - Reprogram DME Control Unit: There is the possibility that an implausible oil pressure will be measured and stored in the DME control unit after switching off the engine on the affected vehicles. As a result, this can cause the oil pressure warning light to be activated unnecessarily in the instrument cluster the next time the engine is started. Reprogram DME"
Doubt DME needs reprogramming as the "implausible" error gets reported if fluids never get up to expected temp range, vs zero reading whatsoever.
you've already had the sensor replaced previously not all that long ago, double checked and cleaned the connector and contacts.
Error keeps coming back? Sounds like bad connection somewhere along the wire harness
sorry to say this but dont discount rodents. we dont like to think about it, but they can get in there and chew on the wires.
Yes. Mine failed a few years ago and had to replace.
