Anyone Running Fabspeed Bypass
Close to buying a bypass after lots of YouTube and research and then came across the newly design fabspeed bypass with the curved oem style balance tubes.
Kinda makes sense, wondered if anyone has tried one yet and could let me know your opinion and what it sounds like?
Link below...
www.fabspeed.com/amp/porsche-997-gt3-gt3-rs-center-muffler-bypass-pipe/
Thanks all
Link below...
Thanks all
It looks nice and has some reinforcement welds too from what I see
I have the M&M/FVD center, which like the Sharkwerks CBP, is not connected to the other side
Also, mine uses the stock clamps to hold it in place which is needed especially if you also have the side bypass(I have valved Soul sides)
There was a Softronic thread discussing some of this. I now wonder what the Singer cars with the Williams engine use for an exhaust since they come from the F1 world with lots of data and years of experience. You can see their exhaust exits separately but who knows what it looks like behind the bumper etc-
Here's the Softronic discussion, towards the end of the thread:
https://rennlist.com/forums/997-gt2-...ennlist-3.html
John
John
GTTommy (08-02-2021)
Link below...
http://www.fabspeed.com/amp/porsche-...r-bypass-pipe/
Thanks all
Link below...
Thanks all
Mine has the older Fabspeed version with the straight balance tube, It is the only mod I have and it does sound great. With the Sport button off, it is almost as quiet as the factory center muffler until you hit 4,000 rpm. Then it sounds like a GT3 is supposed to.
It is even better with the Sport button enabled but it still reasonably quiet below 4K. It does have a noticeably louder idle, though.
I didn't care for the Fabspeed extensions and had these made from 304 Stainless for a more aggressive look.
Basic Sponsor
Link below...
Thanks all
Link below...
Thanks all
Shoot me a PM or email for our Rennlist discount!
The following 2 users liked this post by Fabspeed Motorsport:
GTTommy (08-02-2021),
Steve Theodore (11-16-2021)
John
John
I'd imagine the cup cars don't have the balance pipes as they are just interested in the top end power rather than mid range torque?
It's interesting for sure though!
jackb911 (08-02-2021)
The Fabspeed outlets that the extensions attach to are an odd size. but I don't recall exactly what but I am pretty sure it is around 2 3/4" . Here is a page from the Heartthrob site that lists several different sizes.
http://www.heartthrobexhaust.com/straighttubing.htm
As indicated at the top of the page, they will cut them to size for you. I had mine done several years ago in the 304 stainless and polished the outsides with 0000 steel wool. They are a perfect interference fit as shown in this underside shot.
The outside of the outlets are around 90mm. I got them from a hot rod exhaust company in Minnesota called Heartthrob Exhaust.. Everything there is in inches, not mm.
Ordered, nearly went sharky but fancied something different...
Coming in a few weeks, pics and findings to follow...
Ok, took a lot longer than expected to arrive...but its here and fitted...
Quality is oem+, the fit is oem and the sound is unreal, its not changed the sound of the mezger like some of the bypasses seem too, I. E. it's not high pitched, it's oem mezger on steroids, no drone cruising at 70 either!
Flat6997 (02-25-2022)
Wow, looks great. Post some sound clips if you can.
