‘11 GT3 RS 4.0 Battery
#31
Voltage is Voltage amongst lead acid/agm (even though very minute output differs). Litho option in the Porsche tool can be selected for account for the charge rate.
Amperage is obviously different and your car “shouldn’t” know the difference.
I’ve seen H4’s installed over the years in various GT3’s at cars/coffee events. As said before, “ain’t no thing.”
#32
The Porsche Scan tool PIWIS. There maybe other tools such as the Durametric that may have the function. I'm sure they'll chime in shortly as I only have specific tooling for my wife's Cayenne (most modern Pcar at the moment; a/c cars use the Hammer). Back in the day though, we went through a private shop for the .2 when the family briefly had one. I searched for a used oe battery that eventually failed as was common (unknown to me at the time). Had to switch back to agm. Others can chime in about that experience I'm sure.
What's your usage though? Litho's have some special treatments that are needed outside of the agm/LA types.
#33
The following 2 users liked this post by Khloesdad:
Antigravity (07-16-2021),
Steve Theodore (08-06-2021)
#35
I have had the Anti Gravity H6 60AH battery in my 997GT2 for over a year, the only issue I noticed is how much faster it cranks the engine compared to the old 80AH lead lump.
The following 2 users liked this post by TB993tt:
#36
It’s because of the pulse amperage. Even my little 24C has around 420.
When I was referring to H4’s, they were the AGM/LA type.
Earthx or Voltphreaks are good options as well. They’ve been around for sometime. I’ve been using ETX24C’s Litho’s since ‘16 with not an issue.
#37
Premium Sponsor
Best regards,
Chad
chad@antigravitybatteries.com
#38
Hi Laguna, yes, you should be able to just drop this in and go.
Best regards,
Chad
Best regards,
Chad
The Mick (07-19-2021)
#39
I ordered the battery Thursday night and it arrived Saturday. Was super easy to install and could not believe the weight difference and savings. Insane!! Seems like a no-brainer upgrade. Super satisfied with my purchase!
The following 4 users liked this post by Laguna_Dude:
#40
#41
the tech is now to point where i don't see these as being less reliable. I could not believe the weight savings. while they are street cars, they are sports cars and obviously lighter is better for sport driving.
#42
Because all of you warm weather fellas don't have to start your GT cars at 10 degrees. And arguing over battery weights is hilarious. Cranking amps are king.
#43
i agree. but it is a meaningful savings. and op was claiming they won't start in summer or warm weather. i think these new batteries will work fine. and i dont know anyone who keeps their RS outside in dead of winter in Montana. It's not a ford pickup. i am happy with my purchase but to each their own really. everyone has a different reason and purpose for things. i wanted the weight savings. and it cranks up as fast or faster vs. the heavy lead-acid that it replaced. 992 GT3 comes with LiFePO battery as standard.
#44
I also have a 30 Ah Antigravity in a 964. I like the drop-in shape / sizing and the technology seems more developed. OTOH, hard to argue with the reliability of a hardwire low voltage cut-off reset on the Voltpheaks (vs wireless for Antigravity). And the Voltphreaks also has a integrated battery cut-off switch.
So far the low voltage cut-offs in both have worked flawlessly (ie when they've kicked in there was enough charge to easily start the car after a reset). My 997 GT3 can sit for 7 days before the Voltphreaks cut-off kicks in but I usually have it on a tender or use the battery cut-off switch if its going to sit.
