I’m missing a few of these under panel clips. They are the 4 clips needed for the transmission cover to be fastened. Can someone help me identify this part so I can order it? I appreciate your help.
I had this panel off yesterday. Torx screws do attach that panel, and, coincidentally, I had just picked up a few of them from the dealer. The PN they used is 9A7-007-698-00 (round head screw).
Also be careful tightening the plastic/nylon nuts that attach to the studs on other panels-they will rip the stud off if over tightened. The ones you're replacing should be tightened quite a bit so they don't fall off like they did. Or someone might have forgot to put them back in.
Thanks for the info. I need the metal insert that goes in that bar. Basically the part that the torx screw bolts in.
It was not an easy task since this part doesn’t show in the diagram. I will order it and will report back with the findings. Also, let me know if you find another one that may work.
