, need your advice I am installing cams for 997 gt2 for both bank... My plan is to 1st install bank 1 cams rotate the engine 720 degree than check if bank 1 timing is ok.... Than after again rotate to 360 degree install bank 2 cams with Porsche tools .....
While I tried to go with this method, I felt heavy resistance before completing 720 degree... So I Did not push hard... Chain is not strucking( bank 2), what do you think the problem is
