Navigation delete 997 gt3 with Durametric
4th Gear
Hi, I have removed my head unit (navigation) and the map dvd changer from my 07 gt3. I have tried to code it away with my durametric pro cable but still get faults for PCM display in both the “Instrument Cluster” and “Gateway” sections. Anyone know the correct coding for this “radio delete” when having the navigation unit removed?
Many thanks in advance for your kind help
Regards
Johan
Regards
Johan
You're not getting any dash warnings and don't have any "empty" selections on the multifunction section, right? I'm pretty sure you just code out the gateway and cluster.
I'd need to check mine again...
What codes are you getting in which modules?
4th Gear
Hi, I do not getting any dash warnings.
I've done the following coding:
"Instrument Cluster"
- Radio = Not Installed
- PCM = Not Installed
"Gateway"
- Radio Gateway = Not Installed
Based on the above I'm getting the following codes:
"Air Conditioning"
- C141 Communication PCM (display)
- C131 Communication Gateway control unit (CAN Comfort)
"Airbag"
"Gateway"
No faults
"Gateway"
"Air Conditioning"
"Airbag"
"Gateway"
No faults
