A tale of 987.555.86.300
A totally non-critical part that opens the door failed on my car /s. I figured I’d pay the Porsche tax and it would be an easy fix, turns out, I was wrong ![order](https://rennlist.com/forums/graemlins/order.gif)
“Thank you for contacting us. Unfortunately that part number you have supplied is no longer available through Porsche. Looks like they have discontinued it. See below.”
Probably spent a few hours iterating over the various designs and hours, and hours learning how to generate toolpaths in Fusion and operating the mini mill. For sure a learning experience, but pretty cool to go from design to physical part.
This casting retained a pin that held the pull strap in place. Well, it was supposed to.
![](https://community.carbide3d.com/uploads/default/original/3X/4/d/4d0ee5d750b950e1d119ec0d88f3a47ed2b23545.jpeg)
This is what it should look like (passenger side).
![](https://community.carbide3d.com/uploads/default/original/3X/4/f/4fc4cfb64aa41cc8c1cc93efce02c0a1a0940e39.jpeg)
So I modeled a part, and then realized I 100% didn’t want to machine it.
![](https://community.carbide3d.com/uploads/default/original/3X/1/b/1b10ce3f1eb8491e6c9277611de932e029a8a2db.jpeg)
So I tried to simplify the design. The new part slips on and will be epoxied over the existing door handle where the existing adapter screwed to.
![](https://community.carbide3d.com/uploads/default/original/3X/a/6/a671a574df1ab5e9bb6b497e225c943f6162c046.jpeg)
3d printed the first few prototypes
![](https://community.carbide3d.com/uploads/default/original/3X/6/7/677a2108bc9885e4d739833f32d1eb791af531a4.jpeg)
![](https://community.carbide3d.com/uploads/default/original/3X/3/b/3be490e00c9f9a6860079d6208a3a3a83a89b97a.jpeg)
Then proceeded to crash a few end mills
![](https://community.carbide3d.com/uploads/default/original/3X/6/b/6be38740c9583a8311e98fbab86edb7ae0fd5d3e.jpeg)
![](https://community.carbide3d.com/uploads/default/original/3X/4/3/432589ef5d05a7c5ceb842361d88b73de0dcc704.jpeg)
![](https://community.carbide3d.com/uploads/default/original/3X/e/b/eb04b0b8d9b6cffa4135fba540a35635108d9d96.jpeg)
![](https://community.carbide3d.com/uploads/default/original/3X/6/d/6d9daa6bec2686444889c38125ca1e2bc9eaca1e.jpeg)
The following 6 users liked this post by ngng:
cbracerx (06-02-2021),
CRex (02-01-2023),
GM.RS (10-20-2020),
LCCHOU (02-03-2023),
Steve Theodore (01-31-2023),
and 1 others liked this post.
Agent Orange
Great job! Is it the same part for both the driver and passenger side? And are you able to produce more by chance? I'd be interested in a set if so. Since this part failed on you it will likely fail on others...
not sure I want to sell them just yet, it's pretty crude haha. I'm OK with it, mainly because I can't open my door without it. this part would fit on either side.
porsche doesn't sell the full actuator? I recall a long time ago when i changed to pulls on my 997.1 i had to replace the full internal part...
I see a market here for someone.....ngng.
SupraSaiyan (01-31-2023)
I hit it with a whip. Had I known what I know now I would have done a 3 thou chamfer pass on all the edges. I also would have calculated my feeds and speeds vs dragging a slider to max 😂
