2002 gt2, engine stalls while AC turned on
Hello everyone,
My gt2 idles 700-800 rpm with AC on / off... If I drive it with AC off it works fine, but if I turn on AC during idle & than drive it, engine stalls within 2-3 seconds..
i tried to find idle air control valve , can't find in this model & tried clean throttle.....
It never improved..
What you guys think ??
It never improved..
Bad clutch in AC compressor?
Dwad (08-20-2020)
Agree with RAudi Driver, sounds like something wrong with compressor. Could be bad bearings or anything making compressor too hard rotate and so it simply stalls the engine @idle when engaged. That's the generic culprit, but your issue could also be something 996 specific. See if anyone on the 996 forums has had this problem.
Dwad (08-20-2020)
