Advice Sought
Again, Low owners by itself is not a clear indication, but all other things equal on a flawless car, most people would prefer low owner numbers, especially if the most recent owner has been for a long period of time.
Total myth. My car had 2 owners in the same family for the first two owners and then owner 3 and 4 were collectors so it moved from two collections quickly all in 9,000 miles. Car condition is everything...
personally I find it hard to give advice on which car you might want, since I have no idea if you are buying this as an investment or as a driver (& even then, street or track?).
27k miles is a tad up there,... plus I find it hard to believe that all those price points are equal cuz there's no way you are finding a 991.2 GT3 manual for the price of a 997.1 RS (w/ 27k miles). If you HAVE, then buy that one (cuz at that point who cares about depreciation!)
=Steve
=Steve
I suggest you drive an 07/08 RS first before considering the swap. IMHO there is no discernible difference between the standard GT3 bar the flywheel, assuming both cars are either comfort or clubsport spec. The delta in price is definitely not worth a C4s. If you need to keep just one car, add some tasty mods to the GT3, it doesn't take much for it to surpass an RS as a driver's car.
Thanks for all the comments - the current cars are in fact part of the problem - my current 2007 GT3 is a 20k mile car and the 2008 C4S a 25k mile car. Both are exceptionally clean drivers but not clean enough to warrant treating them as "collectibles". The GT3 RS does have a dose of extra cachet however that is also an indicator to keep mileage down - which seems to defeat the object of owning what must be among the most epic enthusiast's cars ever..
& there in lies the problem. If you buy into the "exclusivity" montra,.. then you'll tailor off as being a driver. At least of that car anyway.
be honest with yourself. Are you swapping to the RS because you want appreciation, or at a minimum for it to retain whatever value point you buy into it?
