997.1 RS spolier
No, you need the decklid to go with it. Just look at some pics and compare
I wish!
Airbox is the same, but if you only want to slap the wing blade on then you're out of luck. The taco decklid has an entirely different mounting system than the .1RS decklid. Will bolt on to your car with wingblade + decklid, the decklids themselves mount the same on narrow and widebody cars. Same goes for .2 GT3 decklid + wing, will bolt up to your .1 GT3 if you have both. .2RS will need the addition of a shorter gas shock, forward trim piece, and .2RS or Cup intake.
Hope you have a setup on hand already, genuine OEM setups are like $12k+ from Porsche.
