What Part Number Do I Need
I'm replacing one of my rear wheel well plastic deflectors. This is the piece that attaches to the rocker panel just before the rear tire opening. There are 2 screws that attach it to the inside fender liner and 2 screws that attach the bottom to the underside of the rocker panel. In the body itself there are 2 square (almost) holes that have an insert clipped in that has the threads to accept the screws from the bottom. I'm missing one of these and apparently none of the diagrams Suncoast has depicts them..
The clip #13 is incorrect on this drawing as it actually is the clip that attaches to the inside lip of the wheel well opening and is bonded to the vertical portion of the part itself.
Also, apparently the 997.1 is different than the 997.2 GT3.
This is part #13 in the diagram and is incorrect.
Here's a picture of the hole that shows where it is
Close-up of the hole
Here's a picture of the other hole with the clip I'm looking for inserted.
The Rebel
This is what I think you're looking for:
Part No: 99950759002 which has be superseded by Part No: 99959162901 ($0.89 retail and about $.63 wholesale)
The reason why I believe you and Suncoast couldn't find it is, this is a captive nut which goes attached to the car/chassis/frame rather than part of the wheel liner or wheel liner deflectors.
Good luck!
Good luck!
Good luck!
Good luck!
