997.1 GT3 BBS E88 Question
Howdy,
For those running 18x9 or 19x9 front BBS E88s what size rim halves are you running? 1" outers and 8" inners? Thanks in advance!
Best Josh
Best Josh
Front: 9x18 et 50 0288274 ctr (1” and 8”)
I have an RS so rears are different
You were the two folks I hoped would respond. Thanks very much! Perfect. Greatly appreciated.
Yo K! We gotta pick a Friday to do the exhaust. And my long tube headers are yours if you want them
Best JBO
Best JBO
GT3 player par excellence
josh, listen to spyerX.
his spec will work
my will rub ;-)
his spec will work
my will rub ;-)
LOL! J, I've had a set of your E88s on my car but I bought them from the prior owner with tires so didn't see the barrel data. You have tons of BBS floating around out here
^ I used to. but at 19" and bigger I moved to mono block BBS. no more super wide barrels.
BBS Motorsport wheel e88 for 997 Porsche GT3 and GT3 RS
997 GT3 non Center-lock
Front Uses 0288274 center / 1.0 outer / 8.0 inner ET + 50.0
Rear Opt 1 Uses 0288108 center / 2.5 outer / 9.5 inner ET + 64 w/o factory 5mm spacer
Rear Opt 2 Uses 0288107 center / 2.5 outer / 9.5 inner ET + 68 for use with factory 5mm spacer (effective ET is + 63.0)
997 GT3 RS non Center-lock
Rear Uses 0288108 center / 3.0 outer / 9.0 inner ET + 51 for use with factory 5mm spacer (effective ET is +46.0)
