2008 GT3RS Engine Air Filter Change
Yes the box has to come out in order to change the filter.
Just loosen the hose clamps on the boot from the airbox to the throttle body, unclip the MAF sensor, and then lift the airbox up and out.
Once you have removed the airbox assembly you can undo the ten thousands screws that hold the two halves together.
