Garage Lifts?
Garage Lifts?
In today's edition of First World Problems, my pending addition to the stable will exceed my garage capacity. So I'm looking at a lift to store the RS, and to do maintenance on it and other cars. I don't know how much the clearance differs between RS models, but the one I'm trying to find a solution for is a 997.2.
The challenge I keep coming across is finding a lift and sliding/rolling jacks that are known to clear the undercarriage of the RS when driving it on. For example, I've been looking at the Bendpak HD-9XW and its RJ-4500 jacks. The problem is there isn't a clear dimension on how high the jack sits with respect to the ramps the car will drive on. When I called and talked to a sales rep at Bendpak, I was told it's "about 3 or 4 inches". One of those numbers would work, but barely. The other would be a pretty extreme... interference fit.
Without being able to get a straight answer from the manufacturer, I thought I would try posting here to see what lift configurations others have and if it worked out of the box or if you were able to modify something to make it work.
My ideal set-up is a 4-post lift with 2 sliding jacks. I just don't want to buy and set all that up, only to realize there's a 1/4" stopping everything from working together.
And who doesn't like an opportunity to show off their garage set-up if it has a lift in it?!
I've got both 2-post and 4-post lifts I use to store and service my cars. When I went to put my GT3 on the 4-post lift after I first got it I found out that the ramps for the lift didn't have a long enough approach which caused my GT3 front end bottomed out before actually getting on the lift. Luckily I had my Race Ramps in the corner and used them to help get the GT3 on the lift with no issues. SO you might also want to look into this as well.
Now, back to you original question on the rolling jack clearance.... I've used these in the past on trailers and thought they might work great for your situation. They would give you additional clearance between the rolling jacks and your new RS....
https://raceramps.com/car-ramps/trai...trailer-mates/
I owe you one, thanks!!
I just installed an HD-9 w/ 2xRJ-45s. With the rubber pads on the furthest point, they will clear, but will hit the brake ducts. Those are flexible, so it shouldn't be too much issue. You can leave the rubber pads off and then install them before you locate the RJs at the lifting pads. You'll have to stop at the wheel well to get enough space to install them, but it's doable. If you email with Bendpak, they will tell you 2 3/4" above the rails on an HD-9 without the rubber pads. With the pads it's closer to 3" clearance. I can sent pics later if it will help.
I have the Advantage 4-post 9000# Lift with their rolling scissor jack. My low GT3 clears the jack with no problems regardless of which position it is in. Backing onto the lift can be done with the standard length aluminum ramps with no scraping. Go on forward I use my Race Ramps which work perfectly.
Advantage 4-post Lift
I think quality is very good and service has been excellent.
Saw this at AMG academy at COTA. Two post with no drilling required.
That doesn't work for what I'm trying to do, but that's a nice set-up!
Agent Orange
The Finkbeiner looks very interesting! Just spent a little time on their site... You can buy storage ramps for it too: https://www.finkbeiner-lifts.com/pro...f113b156896cfa
This is the classy solution I used last time I put my GT3 on the lift.
My dad Has the following Lift: http://www.worthequipment.com/parkinghobbylifts.htm with the lift ramps and I do not think he has had any trouble with his 2010 GT3 and the ramps. He uses it to both work on cars as well as for storage and it has worked great.
