Header v-band clamp help
Im looking to see if anybody has a pair of exhaust clamps or if anyone has a part number for them. I have a 996 that I converted to Center exit using gmg 200 cell headers and fabspeed rear section and I need the clamps that clamp the headers to the rear section. I have v-band clamps on there now and I’m constantly fighting exhaust leaks. Any help would be great, thanks.
pics would help...but they have a silicone that is for making gaskets you can use its like an orange color..if you put some on the sealing surfaces let it set for a few minutes then install the vbands...dont turn on car till it cures..
![](https://cimg0.ibsrv.net/gimg/rennlist.com-vbulletin/640x477/de7d6e73_5ac4_4900_97f2_16ad3a6f0fcd_104693c1904e795213dbfe26be12fed4c6e76974.jpeg)
There is a donut gasket
The clamp is: 99711133690 ~$175 each (ouch)
The sealing ring is: 98011156100 (yes a CGT part!) ~$20 each
The clamps and seals the header exit to the side mufflers OR to the side bypass pipes if you're using those.
