Longer 6st gear possible?
I have a .2 GT3, which are running a shorter gearing than stock. I'm fairly sure that I have either the RS R/P or a Cup one. (Redline in 6th are aprox 186mph/300 kph)
As I do quite a big part of my yearly miles on autobahn to the Ring, Bilster Berg or some Swedish tracks, I would love a longer 6th, but keep everything else as the lower general gearing really works on trackdays.
Is this possible? I seem to recall that the .1 runs a longer gearing, but is that only in the R/P? Are there other 6ths available for an "easy swap"?
Thanks!
Thanks!
Going off memory,
.2RS had different gearing in the box in addition to a different ring/pinion.
1.GT3, .1RS, .2GT3 all used same gearing
So if you just put a different R/P you'll have overall shorter gearing. So yes, you can change them to match the R/P
So to keep my shorter overall gearing, but extend the 6th, I would need to go outside OEM?
Does that exist? Probably not. Would only be usable in my specific case or if an .2 RS wanted a longer 6th
Well, had to try it once or twice going through DE to Bilster or Ring.
But much fuss though. My Supra is more white knuckle that the GT3.
Would really like to be able to cruise at lower RPMs though. Annoying keeping 100+ mph for longer periods. .2 gt3 should be better here
You want the .88 6th gear found in the .2 RS, or maybe the 5th gear from a 997 GT2. Those should move you into the 192 to 194 mph range depending. I believe that ratio was used in other cars as well. My first call would be to Guard Transmission to see if the have the part. Straight cut aftermarket gears will make noise, probably not what you want for cruising, so I’d try to stick with the factory parts if you can get them.
edit: look for PN 997 302 956 90 (.2 RS 6th)
Looks like it’s pretty available, ie: https://nemiga.com/cat_spares/etka/part/99730295690/
Agent Orange
According to my research the gearing on the 997-1 GT3 & RS and 997-2 GT3 & RS is the same. They all have a 0.92 6th gear but the 997-2 RS has a 3.89 R&P, while the rest have a 3.44 R&P. The 4.0 uses the 3.89 R&P but 6th gear is taller, 0.88. I am using that 0.88 6th gear in my 993 close ratio transmission rebuild.
Having owned a 997-2 GT3 I didn't find 6th gear to be too short. But my current 997-2 RS could use a taller 6th and when the time comes for a tranny refresh I'll be buying the 4.0 6th gear again.
Agent Orange
Hmm, I've done 165mph in mine in 6th and the car definitely had more acceleration in it, but the driver's palms were getting really sweaty... BTW hard braking from those speeds is quite the feeling. You better hope you have a working diff!
Think you are right about that, come to think of it
I feel certain that’s not correct. Porsche’s official documentation lists the 997.2 RS as .88 (below). The PET also lists the gear ratios and backs that up. Finally driving both the 3.8 and 4.0 back to back I saw no difference, and I was looking. Both GT3s and the .1 RS have the .92 6th, but unless I’m nuts the .2 RS gets the .88, same as the 4.0.
So going to .88 from .92 with a 3.89 R/P gives me 8 mph more in the top. No too relevant, not sure I'll ever go there again. @ 3000 rpm I'll be going 68 mph as opposed to 65 or 102 mph in stead of 98 @ 4500.. Hmm.. Not going to matter a lot regarding getting rpms down on longer cruises.
If it was a free upgrade, it might make sense, but in this case, I think not. Sadly.
The same rpms but with 3.44 R/P in stead (back to stock) gives me 207 mph (not possible, i know) vs 183 @ 8400, 74 as opposed to 65 @ 3000 and 111mph vs 98 @ 4500. Now these are changes that matter.
Buuut I don't think I would be very happy about giving up the gained performance on track.
I don't have any measurements, but the difference in acceleration with the 3.44 vss 3.89 must be quite a lot
Agent Orange
Pete, you are correct! I had my files mixed up, sorry about that.
Sweet info. So assuming my gears are stock 1st through 6th, and its only my R/P that are replaced with RS or Cup, I will get a longer 6th by using the .2 RS or 4.0 RS 6ths.
72mph @ 3000 rpm
85mph @ 3500 rpm
95mph @ 4000 rpm
The 3.8L engine has plenty of torque in the lower and mid range RPM and I think a taller 6th would be better suited for that car.
Meanwhile I just removed the stock 0.775 6th gear from my G50/20 transmission. It is a VERY TALL gear and makes no sense in a lower HP car such as the 993. I practically never used 6th in the 993. But I might put that gear in the RS when the time comes to refresh that transmission.
Interesting on the .775. Many boxes would be compatible with the GT3's? I would ask a well renowned shop here to do a swap, and they would probably have a bunch of boxes to cannibalize from.
Regarding the R/P, you are saying that the trade off in terms of higher RPMs, wear (?), and noise for long stretches is worth it, as my primary focus on the car is to be able to track it 5-10 times a season.
- and going back, when I only have driven it with the 3.89 would be an impressionable step down in all round accelerative performance?
