.1 GT3 top end rebuild; What pistons and cylinder heads?
Got a high milage 997.1 GT3 that will get a top end rebuild and the coolant pipes fixed. What options for more power are there re pistons and cyl heads? Any Cup car parts that would add some HP? Any high(er) comp pistons available from Mahle motorsport etc?
Right or wrong i don’t know, but I’m not too much into big bore conversions due to everything that’s been written about harmonic vibrations etc in the 3.8/4.0. Besides, I actually like the caracter of the 3.6 with a LWFW.
Engine mods so far: a Cargraphic ”kit6” exhaust with their ECU tune (headders & 200 cell cats + valved side delete’s). Also a dual intet Porsche MS airbox with a .2 RS declid (replica).
I’ve also considered adding the .2 RS plenum/intake. By the look of most dyno graph’s, power seems to flatten out a bit from 7.5K and up.
Some .2 GT3's and some RS's have bolts came loose, some of these cars don't. There are measures that can be taken to prevent possible issues such as Harmonic damper from Dundon Motorsports, and/or get updated OEM cam actuators(with I think they applied thread locker and assign a different part #) or Loctite the actuator bolts and crank pulley bolt, or modify the actuator to accept larger bolts(for higher clamping force) and Loctite them.
Tom,
Thanks for the offer. I've pretty much decided to not go down the big bore route though. This is more a refresh of a stock motor then a big budget build. But, since the motor is out and partially opened anyway, I'd like to understand if there are any gains to be had by using other parts vs OEM.
Reason for asking about Cup heads is that I might be able to buy recently rebuilt ones of a -09 3.6L cup car (#997.104.016.92). Don't know the cost yet though. I also know that the 04/05 996 RSR used higher comp pistons (same stroke and rod length) but they might not be durable enough for street use. Any other 100mm options?
IMO, OEM parts is a known quantity for those who doesn't have the desire to creating their own formula and feel that the OEM quantity is adequate. This is how I feel lately because I am occupied by many things. LOL
