Difference in suspension parts vendors
Are MS parts the same as OEM parts? I'm thinking no, but why should I not consider OEM parts from a GT3 or GT2 RS when applicable?
For instance, for front strut mounts, I was going to replace the stock mount (997.2 GTS) with an adjustable ('reversible') monoball mount.
I see several of these from the various aftermarket sources for $4-500 a pair.
However, If I look up the OEM GT3 part at Sonnen, they are $90 each; way less than aftermarket.
https://www.sonnenporscheoemparts.co...bC1oNi1nYXM%3D
Are these monoball and reversible? What are the differences to MS parts?
Any know of the corresponding MS part to the front strut mount for comparison on features and price?
How do I possibly figure all this out for the various parts!!
The motorsports parts are generally very different. Typically they are a mix of more robust and adjustable. Cost wise, figure 2-3x over 'normal' oem parts. The MS shock mounts will look much like the OEM, but the bearing is heartier
Ray
Ray
If you call Sonnen, speak to Neil,Gina,Ray or Greg and they can get you Porsche Motorsport parts at the best prices by far. I have a wholesale account with them. Greg couldn't find the part number for me on one item and put me in touch directly via email to a head-hancho in HQ. The gentleman responded (shockingly) and told me who the manufacture is however that part is not sold individually from parent part #. Anyways just my experience w/ Sonnen for 12 years. Great team.
As far as upper mounts go, the link you list above is NOT a monoball upper mount that is used on the GT2/3/Cup cars. Those mounts are the regular run of the mill street parts with a rubber bushing. If you want monoball mounts, you have several options from aftermarket to OEM. Pictured below are the following monoball upper mounts: Aftermarket street, Aftermarket Motorsport (same as street but thicker plate), and OEM Motorsport. The OEM Motorsport mounts are the most expensive at about $800/pair while the aftermarket ones are less than half that. The OEM street GT3 upper mounts are the same parts as Motorsport in this case. You can purchase a replacement bearing from MS but not your regular dealer. Hope that helps.
