LIon battery dead
I guess we're coming to that time when a lot of owners will suffer the same fate. Smart charger started clicking off at 3/4 charge which was the first symptom. Left the car overnight in the trailer with Traqmate still connected and key in ignition (bad!) in 90 degree heat. Battery completely dead. What a pain to push out of the trailer, jumper the trunk circuit, and get to the battery.
Went with the smallest of the OEM lead acids. Put the LIon on a Battery Tender (Smart charger just gives error code) for 2 days and load test gives good readings, but it starts to lose charge pretty fast. I guess I could use as a track only battery for a little while longer, but I'll leave the trunk open anytime it's in the trailer.
I got a deal when I bought the car. I think the option price was $1500. Parts Dept wants $2500 for a new LIon.
Possibly a bad cell and if the Li-Ion cells are not balanced that is bad news and a fire hazard.
YES. DO NOT CHARGE IT!!!!!! Dispose of it.
I persisted with a hypothetical method for cell recovery.
Then placed the battery on a normal tender/charger.
Approx 15mins later I heard a pop, couldnt immediately notice anything then a further 5 mins and another pop.
This time, I saw smoke billowing from the cracked battery casing like steam from a kettle.
Panic was the first emotion, with the realisation that there must be intense heat associated with the failure and this heat was sitting right on the fuel tank.
Big breath and disconnected the battery and raced it outside where it spluttered and smoked for a further 150 mins!!
Then my research revealed something about LiOn cells, unlike their Lead Acid cousins Lithium cells are 100% efficient on donating their energy to collapsed cells, so while your battery is effectively dead at around the 70-80% discharge mark there is still significant energy within.
So I am in accord with others in the thread, dispose of it quickly and properly
Yes, when they fail they are basically a flare. One of my hobbies is rc helicopters (like 5-6feet long) most are lithium Ion and yeah when they fail they do so in an epic fasiion.
Yes, I learnt a lot from trying to bring a dead LiOn back from the dead, not much of it good either.
Basic Sponsor
We've had several li-ion's implode (rc hobbiest also), not fun!
I believe you can revert to a standard battery, but I'd check with your tech first because the li-ion states it needs special programming to instal in a car that didn't come with it from the factory.
The Rebel
First to the OP; dispose of it as I can assure you these are not the kind chemicals and other things you want to have to deal with. There are safe ways to test the battery, however first and foremost get it out of the car.
You can replace it with any other battery however you will need to let the ecu know you're no longer running a Li-Ion.
We replace many batteries on P-cars as they seem to be abnormally draining (pun intended) on their batteries. We have installed several brands of Li-Ion batteries but through experience (product quality and customer service) we are now exclusively a Voltphreaks facility.
Voltphreaks are here on Rennlist or if you'd like send me a PM and I'll be more than happy to assist.
+1 on voltfreaks.
One really nice feature on their Battery - you cannot get them into a completely dead state. When they get to a certain capacity they shut off, and there is a button you push to turn them back on.
The Porsche LiOn battery actually has built in protection circuits which basic open circuit the battery if the voltage gets too low. additionally the battery monitoring circuits beep once low voltage limits are approached so you are alerted to the recharge needed condition.
Some other LiOn battery types do not have these protection circuits - after all they add weight- we are only talking grams but that's the nature of weight loss. As such those without protection circuits present a larger problem if discharged too far.
