Over revs - range 4
Over revs - range 4
I am a long time 911 owner, but they have all been air cooled, so I don't know much about these new ones. I am looking at a 2011 GTS with 48 ignitions in range 4. If I did the math right, that is only a fraction of a second. Is that something to worry about? This car has been for sale for a while and I suspect that may be why. I would be stretching my budget for this and sure don't want to buy a potential problem.
Thanks.
Thanks.
When did they occur? Unless they happened in the last few hours, the car should be fine. All of your air cooleds could have range 4 equivalents on them and you'd never know.
Received 5,413 Likes
Not a deal killer. Like Skwerl mentioned above, we need the time stamp and total engine hours. Sounds like the guy slightly miss shifted.
Thanks.
Thanks.
This is part of what motivates me to urge anyone interested in a used Porsche to give it a thorough road test. Start with a test ride over a 15 mile long test route which is chosen to allow the driver to demo the car as you intend to use it.
Then back at the starting place you swap seats and drive the car over the same route and drive the car the same way.
With the extended idling from a cold start as you check out the car's exterior and the test ride then test drive followed by some more idling as you then confirm the radiator fans come on on their own as the coolant gets hot enough this should have the engine running around an hour.
A Porsche is not a car to buy on a limited budget. While one doesn't need Bill Gates money to own one of these cars you have to keep in mind the cost of the car when new. Even if you buy the car for half of what it cost new it is still an expensive car. Servicing, insurance, running costs are not insignificant. My local dealer doesn't offer discount servicing even though my cars are 15 and 14 years old.
The general rule for used car buying is to have set aside 10% of the car's purchase price for "just in case". With a Porsche I'd recommend this be 20%.
Even though your check out of the car finds no issues a water pump can develop a leak at any time. A fuel pump can quit at any time. A tire puncture can have you having to buy at least 2 tires. And so on. You need some money set aside so if something happens you can afford to get the car fixed rather than have to let it sit while you accumulate the money necessary.
Range 4 on a 997.2 = > 7900 and < 8400 rpm, not a problem that long ago.
This is a good informative read - http://www.911virgin.com/porsche/rev-range-information/
Enjoy!
Enjoy!
