997 Rear bumper conversion to 997.2 DYI?
I want to upgrade my rear bumper and lights to the updated 997.2 look. Has anyone on this forum done that? And is it a plug and play with the bumper fitment? I understand that the lighting wires might need to be modified but is the bumper swap as easy as some people say it is?
you need
- rear bumper 997.2 (narrow body not the wide one)
- rear bumperettes
- rear exhaust trims pieces
- rear LED tails
- rear control module (the one under the drivers seat) + programming via durmetric pro
you may see on the threads that there are other parts , but the truth is everything else you can re-use (after minor modification).
- rear bumperettes
- rear LED tails
you need
- rear bumperettes
- rear LED tails
- rear bumperettes
- rear LED tails
Is this something that I can do im my garage or do I need a professional? And do the updated led lights bolt to the same brackets as the original? Thanks in advance for taking the time to answer these questions.
remember get the narrow body not wide body bumper (check eBay)
REAR COMPUTER
997.618.260.08
EXHAUST TRIMS or EXHUAST SHROUDS
Left exhaust heat shield 997.505.651.01 -01c (hider)
Right exhaust heat shield 997.505.652.01 -01c (hider)
BUMPERETTES (just in case you dont fill them in.)
99750562505
99750562605
REAR COMPUTER
997.618.260.08
99750562505
99750562605
the led lights will bolt onto the same brackets as the original - but you may have to shave the connectors of the new tail lights a little (i had to). otherwise the connection points may not make contact.
